This afternoon we had a series of thunder showers move through the area. One got quite nasty and then it cleared off.About 2 hours later I heard thunder off in the distance again and told my wife I was going to check the weather radar on the internet to see what was coming. All my antennas were disconnected as they always are during the summer months when I am not actually on the radio.I just walked into the den/radio shack and as I turned to face the computer screen... FLASH! BANG! CRACK! :shock: :shock: happened all at the same time.The house shook and the power went out.Out of nowhere a single rogue lightning bolt hit the power lines at the end of the driveway.Talk about a burst of adrenelin! When I started breathing again I jumped up and ran to the basement to check the main panel.The house alarm was screeming away and would not reset so I had to open the main panel in the basement and remove the battery backup power.Everything looked fine at the panel,no breakers tripped.Next I ran upstairs to the main level and then upstairs again to the bedrooms etc.All the while I was sniffing like a bloodhound for smoke.Everything looked and smelled fine except for the strange smell coming from my underwear. JK. After determining that all was fine in the house I ran outside expecting to see something missing from the roof. Nope,all was fine there as well.Then I saw the high voltage fuse hanging down from the utility transformer feeding my house and one house either way from mine.Next my thoughts turned to what damage am I going to find when the power comes back on. I went back to the basement and switched the main breaker off until the power was restored.If the primary was shorted to the secondary it would have sent 7200 volts into the house. :shock: After the power company arrived and installed a new fuse without incident I felt a bit better. The transformer was not shorted! I flipped the main breaker back on and everything came back to life as it should including the alarm system.The only problem I had was a blown NIC card on the computer. I had a spare and installed it and now I am back on the net.I know if the antennas were connected I would have lost something due to induction. The strike was just too close not to have. Something to consider when the power goes out is to turn off the main breaker if you can until after the utility crews restore power just in case there is a high voltage on the line.Some would say "How do you know when the power comes back on if you have the breaker off?" Easy answer,ask a neighbor,let him be the guinea pig. In my case it was easy as the power crew was just at the end of my driveway about 100 feet from my house.
