So I felt that the lil Wil antenna was not working properly and so I pull the magnet off the bottom and stuck my DVOM to the middle wire that is solder'd to the coil and then the other end that threads into the radio and it showed only .5ohms is that what is should be? Thanks for the help in advance.
