listening to 10 now
I didn't hear you, but made a couple calls on 365. Things are pretty dead here now, but I got to Germany in my mobile this morning.
73,
Brett
Hearing JA's on 365 now...@ 23:15z
Just heard the JA working a KL7...and hearing both sides...band a little noisy but not really to bad...
Now hearing the JA working a station in Chicago...and hearing both also
Conditions not to bad
All the Best
Gary
Had a strange issue so I needed to shut down, I was getting serious RF in the shack. I have never had this issue before but the rig went to only what I can describe as an oscillation. The power supply nearby went into overload and shut down, the rig is not plugged into it, its powering my VHF stuff. I loaded the rig into a dummy load and all is fine but when connected to the antenna I am getting issues. I have a feeling its something with the antenna, it's been really wet here the last few days. If it's not that then it's the tuner, either way I will figure it out.
Was that busy on 28.430, around 00:00 z, Amp got to hot and had to shut down.Made over a dozen contacts into the states until the amp got that hot electronics smell.:biggrin: Vk4AAP. Ps W9CLL could do with the rain over here the grass is that dry that it goes crunch under foot and breaks.hope you sort your problem out.
