Looking for a Xtal XCB-71 CB Service Manual
danmcclain
I Support WorldwideDX.com!
Dec 11, 2020
877
466
Anyone have a service manual for a Xtal XCB-71 CB? It's not list in the Sams CB Index...
You picked a tough one. From cbtricks.org I found out that's a TC5080 PLL. So it _might_ be similar to the Cobra 132XLR or Tram D62 on the inside. May take posting a board number to find out if there's any sister radios you can use the manual of.
Reactions: AudioShockwav
  • @ Geoexplorer69:
  • @ Geoexplorer69:
