Looking for Sadelta Bravo no Echo
TonyV225
Apr 18, 2005
5,824
331
143
Wisconsin
lm looking for a Sadelta that was made with just the volume no echo in it it is called a Bravo Plus I have one that ive had for years now since mid 1990s its a red base it works but the beep is screwed up if its on the mic keys and I would like to find one simular I run it on my Galaxy 2527 and that radio has the echo already.
these guys have one Tony if you haven't already seen it for 20.00 bucks UK ...www.kcb.co.uk/sechand.htm ......You could always just go with the Sadelta/Galaxy echo master pluses and just turn off the echo on those if you wanted to go that route.
sad bravo plus
Hi i know this is an oldish post and a bit late but u say the beep does not work if mem serves me right on this model as like most of the sad models at the very front of the mic key below there is a cmos ic 40ll surrounding this is quite a few small value caps in (nano farads) ceramics if you replaced all you wouldn't be looking at much money to do this you must keep to the values of the caps if you deviate-no beep'' worth a play.warhorse.
