Looking for some good ideas for covering 160-10m on one feedline...
mr_fx
Oct 8, 2011
1,536
172
173
Kansas City
I have looked at building a multiband 'fanned' dipole
maybe a trapped dipole?
other ideas?
I would even consider running 2 antennas.
I do have coverage for 10-11 meters with my antron 99 I currently have
A really big loop, a 4:1 current balun, a decent antenna tuner, and a lot of space to build it.
A loop will take up less linear space than a dipole will.
But any antenna cut for 160m will be HUGE!
160 meters is mostly a winter time band, noisy as heck during the summer time, for that matter noisy as heck all year.
N4UJW ANTENNA DESIGN LAB - Ham Radio Antennas - Design 0r Build Your own Ham Radio Antenna
Lot of antenna ideas on that site.
One feed line 160 through 10 meters would be an all band doublet 130' of wire on each leg, feed with 450 ohm ladderline and a 1:1 or 4:1 current balun, a good antenna coupler will have this built in the circuit.
The All Band HF Doublet - 80 thru 10 Meter Ladder Line Multiband Antenna
I like the all band doublet. I am using one now until the spring when I can get the yagis mounted on the tower. For cost and performance and simplicity it is hard to beat
i run a
homemade balum and a dipole 134 ft on each side...works with tuner in my ft450d from 6 to 160 and your a99 should work like mine with a tuner from 6 to 20 mtrs...i use it with my ts520 and might fine junk tuner on 10 and 15 and 20 mtrs or the ft450d tuner from 6 to 20 mtrs 73 de JW
Reactions: 2 people
Quite literally, almost anything that conducts electricity can be used as an antenna. That doesn't say how well it will work, only that it will 'work' to some extent. That opens up a huge range of possibilities which then get narrowed down by the practical aspects of what you have available for use (space to put the thing in, wire/tubing/feed line/etc.), and what frequencies you want to use it on.
How well an antenna 'works' is relative. If it's multi-band then you can't expect 'perfection' unless a lot of work/effort/complexity is put into it. It's difficult to combine the characteristics of several antennas into one 'simple' "works anywhere" type antenna. Don't expect 'miracles'.
Now that that's out of the way, bigger, higher and simpler is nice! The use of a tuner is also nice, they make some really 'odd' antennas usable. Probably the simplest antenna to put together is a doublet fed with parallel feed line through a tuner. It's not always easy, but it's certainly 'do-able' for -some- people, not so 'do-able' for others.
Why parallel feed line instead of coax? It's able to withstand more 'abuse' from voltage/current, can handle a higher SWR than coax before you damage it. It certainly isn't as 'easy' to use as coax, but it isn't all that difficult either.
So what space do you have available to put an antenna into, and then, what do you have available to make that antenna out of?
Toying with the idea of making a fanned dipole and using baling wire... cheap, solid core, steel, 16 gauge, baling wire
You can buy 200-300 feet for $5 or less!
Any reason I should NOT do this?
