Actually I think I will move this thread down there were there is more re CB antenna info.
I have a Gainmaster that I was using at the last place, was shooting skip during the low part of the cycle at 4 feet off the ground. Once I finally get out of this HOA (long story) that's probably going to be the first thing I set up after the XYL's stuff. (Survival tip, always get her set up first.)I have the "Sirio Gainmaster 5/8's wave, the antenna beats the daylights out of an A99. The Gainmaster is "Center fed" and has an RF choke on the base by the feedpoint to "De-couple" the RF signal from the feed line.
You can get these Gainmasters for about the same price as an A99.
I have the Sirio gainmaster 5/8 wave, it's far superior to the A99's.You could get something like a Antron 99, they usually can be had for under $100...Or one step up and get a Solarcon Imax 2000 24' for around $130-150...(I would lean towards the Imax before the A99)
Yeah, they're great antennas don't understand why they are only engineered to handle 500 whiskeys, but that's okay.The Gainmaster is a good antenna, there are some long threads here about them and how they work.
Marconi has done modeling on them and even a how to homebrew one with a higher power rating in here somewhere.
100w is all you needYeah, they're great antennas don't understand why they are only engineered to handle 500 whiskeys, but that's okay.
If your a DX operator, having a low takeoff angle is choice for that sort of work. Like you, and coincidental, my Gainmaster feed point is only 4'F off the ground and mounted to a 50lb cast iron patio umbrella stand, my current location won't allow my to set up a tower, no biggie, My Gainmaster performs beyond my expectations at the height I have it..I have a Gainmaster that I was using at the last place, was shooting skip during the low part of the cycle at 4 feet off the ground. Once I finally get out of this HOA (long story) that's probably going to be the first thing I set up after the XYL's stuff. (Survival tip, always get her set up first.)
I have only seen 1/2 wave any ideas where I could find a 5/8 wave?I have the "Sirio Gainmaster 5/8's wave, the antenna beats the daylights out of an A99. The Gainmaster is "Center fed" and has an RF choke on the base by the feedpoint to "De-couple" the RF signal from the feed line.
The walmart.com, buyantenna.com, bobscb.com, amazon.com, and moonrakeronline.com web sites all claim to have it. Copper Electronics also has it on their website, but you have to read the specs to figure out which version it is.I have only seen 1/2 wave any ideas where I could find a 5/8 wave?
I've had a Walmart re loadable gift card I've used for years buying radios and supply's of all types. I keep about $300.00 on it at all times so when I get the urge for something I look in Wal Mart . com and order it and it is shipped to my house. Saves time and travel and never underestimate the stuff they carry !Thank you, decided to go with the1/2 wave from walmart. I would have never thought to look at walmart. Free shipping, thats a big plus!
That's what I'm talkin about............. and even a how to homebrew one with a higher power rating in here somewhere.
