There is a technique that can be used, but it's a transformer inserted into the 120-Volt end of the power supply.
Naturally if you plugged it into a Variac, variable AC transformer you could turn down the AC power-line voltage to get 15 Volts.
15 Volts is 88 percent of 16.9. If we feed 88 percent of 120 Volts into the primary, this would be roughly 106 Volts.
120 minus 106 is 14 Volts. Inserting a 14-Volt AC transformer secondary in series with your power supply's 120-Volt primary winding would have the same effect. But you have to wire that 14-Volt secondary winding with the correct phase. If you turn the leads of the 14-Volt secondary one way, you'll boost it 14 Volts higher. This is called a "series aiding" hookup. Turn it the other way and it will subtract 14 Volts from the 120, a trick called "buck" hookup.
The primary of this theoretical 14-Volt transformer gets hooked to the main 120-Volt source. The current rating of the 14-Volt winding should be more or less equal to the primary current you draw from the 120-Volt outlet.
Hmmm. Just thought to do the arithmetic for a 150Amp output. Would draw more than 22 Amps from a 120 outlet. Not legal.
But a 240 outlet would need only supply 11 Amps. Makes me suspect your power supply is wired this way. If so, just double the voltage numbers in the previous example, and cut the current in half. Makes it sound as if a 28-Volt 10 Amp or so transformer would buck your 240-Volt primary voltage down to where you want it.
