Hello guys, been awhile since Ive been here...have made a lot of changes since then, but as you know I sold all the big stuff off, awhile back....and a forrest fire took out the wire I used to run....so now a days my antenna is here at the shack.....have a Imax 2k, which now a days I usually just copy the mail....
But anyways, Im in the process of building a hinge plate for some mast pipe Im going to through up a 3 element beam on the flat side and go up around 27ft, not looking to get very much height due to my location....this will be setup to turn it by hand or with a pipe wrench...someday Ill get a rotor....
So, my question is, if I go with LMR 400-UF coax, and use a coax choke and mount it on the boom of the beam, would this be enough to stay out of the neighbors stuff ?...
If the brand of coax makes a differences, Ill go with the good brand coax...
Want to go with a good coax, trying to get it all right the first time..
For a radio Im going to be running a Cobra 2000 and a D-104 mic, later will go to some amp, like to have a 2 pill, and or maybe some tube amp later on..
