I have 2x Maco 300 amps. One is a 7 tube, the other has 6 tubes, with the 5th final tube removed.
They both exhibit a strange issue where dead key, after keying for a short time, starts to drop from about 250W down to 100W. After a little while, it climbs back up to regular output and stays for a while. This lag in power also affects peak output. I have tried other radios, antennas and dummy loads.
Thinking it could be the 'lytic caps, I have replaced all. It still occurs.
Has anyone experienced this and if so, what caused it?
