hello all my imax snapped and someone gave me a maco 5/8.i put this bugger on 10ft mast and started adjusting and after 2 days i gave up.i then decided to pull the radiator out and it was bolted through the base at the bracket (some idiot drilled a hole through it)so now the match is adjusting well heres my problem 1.i had this at 1.1 at one time and cant get it back,i got my dip at 27.475 right where i wanted it after many many adjustments.my swr is 1.3 27.475,1.4 27.385 and 1.4 at 27.555 the ring gap is 1 inch like the instructions call will making this gap larger or smaller bring the swr down? 2.when it rains my dip drops down to 26.805 or so is this common my imax never did that?any info would be great.
