MACO 91 ANTENNA MATCHER
  • Start date Start date
B
BOOTY MONSTER
Guest
MACO 91 Antenna Matcher - Palco Electronics
$26 handles 300 watts ..... if pep is kept under 200 watts would this do a good job making a omni play nice across 10 , 11 and 12 meters ? if the antenna is tuned to the cb band , would using the 91 to tune from 24.5 MHz. to 32.0 MHz. have much noticeable loss to the human ear on tx/rx ?
Maco 91
No it's too small and too cheap. You will surely get what you paid for and won't be happy with it. Pay more and get a bigger better tuner if you need a tuner. Even an MFJ 949 Series. I have had several of those and they work great for low power (300w) applications. I currently have a 969.
All of those small made-to-sell-to-CBer's tiny tuners are just little pieces of crap. Stay away. My 7 cents (adjusted for inflation)
Ive got a few of those and the reason why is because they are great little matchers Let me also tell yo I had ran a Texas Star 500 through it not a problem but I am also a SSB user for the most part and occasionaly FM one on a daily basis and have also ran between 700-800 watts through one on SSB by accident when playing with a Texas Star 1600 one day and never smoked that matcher.
I actually purchased another matcher about 1 1/@ years ago from one of the forum moderators here. I purchased it with a few other things they had because I knew how nice these particular matchers are. The person I bought it from also ran a Texas Star 500 through it ;)
You will not be sorry you bought it even if it sits around unused oneday because you will always know you have it on hand incase you do need it and you will know its reliable. yes these will match 10 - 12 meters no problem. These are a great extra for the RCI 2950DX and the 2970DX because it has the radios whole spectrum covered as far as matching or tuning. The only thing I wish it had and Im going to talk to Tom Charles the owner of Maco about is a tune or bypass (through) switch ;)
Reactions: 2 people
That thing may be able to handle 300 watts (Pep), but only if the mismatch isn't much to start with. If there's much of a mismatch, fairly high SWR, seriously doubt if it would handle much power at all let alone 300 watts.
One of the biggies with an impedance mismatch (high SWR) is the voltages involved when a conversion/transformation is made. That voltage can really get large which means the capacitors and coil used for that impedance transformation have to have a high voltage rating. With variable capacitors that means a wider separation between the plates, and larger plates to start with. Voltage handling capacity determines the 'size' of the capacitor. The amount of capacitance required is typically fairly large and a tiny variable capacitor that would fit inside that 'matcher's case puts a definite limit to how much capacitance there will be and the plate separations. Keep in mind that you'll have to squeeze two of those capacitors in there, AND a coil! Sorry Charley, just ain't gonna happen if there's much SWR/impedance difference, just ain't no room for the components required.
That 'matcher' also appears to not have a variable inductance/coil. That's another limitation on how large a mismatch/SWR it can handle.
All things considered, I'd cut that power handling figure by a factor of '10'. That would get it closer to what it will do. Then it depends on the capacitance present and the inductance. You just ain't gonna do much 'matching' with a shirt pocket sized tuner/matcher.
matcher
I was thinking about one of those matchers , though I would be willing to pay a little more for better equipment I go halfway through half the 11 meter band through half the 10 meter band with a 1:5 . and its a 10 meter horizontal V dipole.I am usually on 38 lower sideband as thats where locals ( 10 miles away) come on .
