If you are a Ham; then you might want the A99 or an Imax. I don't know what you have against it. Cheap and usable Ham antenna. My Imax easily tunes on 10, 11, 12, 15, and 17 meters. Same is true for the A99. The V58 is a 5/8 wave antenna that can only do 11 and 10 meters and needs a tuner for 10 meter. The V-quad and 3 element beam will do the 10 and 11 meter bands using an antenna tuner too. The only time I use an antenna tuner with the Imax is on 15 and 17 meters, just to clean up a small SWR difference.
The V-Quad and the 3 element are of course directional beam antennas that will require a rotor and have some usable gain and bandwidth.
I use an Imax and a 4 element Sirio beam, and that worked out well for me . . .
The A99 is a 1/2 wave antenna, and the Imax is a 5/8 wave antenna. It depends how much you want to spend. The Imax is about $100 and the A99 is about $70. I wanted the performance of a 5/8 wave antenna, so I went with the Imax.all im trying to do is get a base antenna with gain i talk to people base to base with atleast 50 mile difference. ok if i had to choose between the a99 and imax2k?
Can some one explain the differences between a Maco V58 , Maco Y-Quad & last but not least Maco 3 element beam.
pro's , con's?
i'm looking to get a good base antenna. no to the imax and no to the a99
thanks.
Your Imax is only a part of the radiator when you use it on 12 15 and 17. The coax shield is doing a lot of the radiating too. Might make some unwanted neighbor friends like that.
that's very true and definitely something you should consider before buying a base antenna without ground elements . neighbors constantly complaining about hearing you through their electronics (tv , computer , phone radio ) and the spouse/kids at your house too will get old real quick . id strongly suggest something with full 1/4 wave length ground elements .
are you just going to be using this with a cb radio or are you wanting to use it on ham frequency's too ? if youre in a area without very high winds or heavy snow/ice in the winter ill suggest a sirio vector 4000 .
Would putting a GPK on the imax 2000 help get rid of the rfi problems?
