the Chameleon. is a qrp loop. im talking about thMoleculo did a write up on one here that you might want to take a look at. I believe it was a Chameleon.
73,
Brett
73,
Brett
thank youhttp://worldwidedx.com/threads/review-of-the-chameleon-cha-f-loop-portable-antenna.192105/
I know there are some home brew ones that you can make for higher power, too.
73,
Brett
ok got a question. i can mount it horz. or vertically. what is the better way.thank you
im thinking vertically. am i wrong?
You can mount it either way.
Mag loops are very efficient if properly designed. The only downside is they are very very narrow banded. Great if you tend to park on one frequency, but if you are jumping around a band, say in a contest, you will be constantly retuning the antenna. I built one years ago out of 3/4" copper tube and a 10KV vacuum variable cap. It worked very well.
