I've read how mag mounts are rated for 3,000 watts of power. Like the Wilson 5000 mag mount for example. But would you trust your amp to use that skinny little piece of coax to carry that much power? What about the amount of grounding - a capacitive coupling type ground - antenna will provide? Surely; there is a practical limit to what one would put through one of these things under these conditions.
Let's say we are running a radio with a 100 watt PEP into a Wilson 1000 mag mount. Although the coax and coil of the antenna can handle that much power pretty easily; is it wise to run that much into it with a 5 inch diameter magnetic base? Just how long can one expect to use a radio with no real ground - except for capacitive coupling - before damage can be expected at 100 watts PEP?
If at all?
If at all?
