I posted this video results in an old thread earlier, but I post it again in its own thread, so it will be easier for me to locate using a thread search.
As noted earlier, I did this comparison test using my VA1 analyzer several years ago. I was trying to confirm the idea that the A99 uses the mast of feed line in order to work effectively. In other words this antenna uses the mast and/or the feed line to satisfy the missing radials. My idea was that maybe the antenna would show a corruption to the match if the feed line or mast was not present when testing at the feed point using an analyzer.
Earlier I tested without isolating the antenna from the mast, and some argued that the results I was seeing was in error...because the antenna was simply using the attached mast. So this time I isolated the A99 from the mast to check and see if that would make a difference.
This is my story for how and why I did this video, to indicate finally that I have some proof <gotproof>, that IMO anyone can test and duplicate.
Here is the video:
A99 test with my VA1 analyzer - YouTube
My notes below are the results when checking the battery in my VA1 connected to a dummy load and to the antenna before I did the video test. This routine indicated to me that the meter was working up to par and had enough voltage. As noted the results were very similar, between my dummy load, and the feed point on my A99. If I had seen a notable difference I would have changed the battery.
Here is the video:
