Marconi Signal Report for the Sigma4 by itself
Marconi
Honorary Member Silent Key
Oct 23, 2005
7,235
2,374
343
Houston
Now here is my SR on the Sigma4 by itself. This test will appear to show the S4 does much better than when it was mounted side-by-side with the GM, but you have to consider the nature of the contacts made with both reports. When I include the random reports in both reports, you will notice the reports appear much closer.
The data in the second position of this report is what I saw on switching my radios noted below the antenna descriptions. Just checking to see how close the CB radio and the Kenwood radio really are. I will add more to the 570 side of this report, but here is the report anyway. I just wanted you guys to know that I'm still working to show some testing, good or bad, and not just a bunch of words while we wait on MrS to get the guys he knows that have done 1000's of hours of range testing antennas to show us how it's done.
View attachment Signal Report #28.pdf
You keep can keep going round in circles with your tests, I am glad you finally use only 1 antenna ... " I" myself personally have done thousands of hours of testing you can believe it or not, ask Bob85 he knows enuff of what I do or anyone who knows me knows this to be a fact and my results have shown that what I do works. I am not here to talk of what i do or how i did it. I am hear to help you put accurate results out there for the world to see who google antenna tests. Your way of testing will make people think that is the right way or thats the results one is to expect. Fly me down to your ponderosa and i will show you. Your only advantage is you live in the South I have a foot of snow still on the ground, but me trying to impress anyone with my test results are low on the totem pole right now. Getting acccurate results with Bar graph meters arent ... Again I am not the only one to say this perhaps you will believe someone else. But it seems you have your mind made up as to what antennas you want to perform... I could give 2 shits which works better, do the test the right way eliminate the variables and no one can say anything You are testing guys with beam antennas for christs sake, . if you didnt want to be critiqued dont post on the web or you tube for the whole world to see. I am not here to make enemies but I am not out here for a popularity contest i could care less if you , or any other poster likes me. Test like these are the reason we have guys on here proclaiming coil antennas give 20% more audio. Now go fire up that bar graph meter rig so we can sit here like stooges watchin it
They are close together.
Given you're only reporting on receive there may be less likelihood of data corruption. I do see MrS reservation with reporting signals generated on beams. Perhaps at one time they are pointed right at you, and another occasion they've swung them a little more to the west, etc.
However, if the S-unit numbers are all within a relatively short time frame, and you are only recording S-units on the same antenna but two different radios by a quick switch of you coax switch, it would take an incredibly quick rotor on that beam to get that beam turned away before you flick the switch. Otherwise, it is not a test of the other (transmitting beam) antenna we're looking at, but a comparison of how the two receiving radios on the same antenna within the same 5 - 10 seconds time frame are reporting the very same incident.
Unless I've missed something here, there's no problem.
I think I'll go fire up some popcorn . . . the show must go on. :)
" I am not here to talk of what i do or how i did it. "
how about instead of being so self righteous , augmentative and oh so willing to gripe , bitch and complain about what others are doing...........why dont you tell us what you did and how you did it ?
or are you still afraid someone is gonna xerox your ideas and become rich off of your forum post ?
When you can add something constructive to the thread do it otherwise just sit there and beg for free info as usual.
No one likes being told they are doing something the wrong way. To bad though that is called "peer review", go look it up. This is a open forum where people all over the world can google, If you think I am giving bad info or test methods post your own.
He was comparing the data from his last test with this one, you think there beams are in the exact same location? and if you read it alot of the guys he tested are using beams, again do you consider that a valid comparison?
Marconi wrote: "This test will appear to show the S4 does much better than when it was mounted side-by-side with the GM, but you have to consider the nature of the contacts made with both reports. When I include the random reports in both reports, you will notice the reports appear much closer
Hey guys, MrS makes a valid point here. I would choose to avoid using guys that only had beams if I could do what I want. This is not the only problem however, guys switch their amps on and off, or use different RF stages, radios, antennas, coax maybe, and who knows what. Sometimes some work a base and other times they're in their mobile. All of these potentials apply with varying results just like the beams can, say nothing about atmospheric conditions. This is the primary reason the sampling of contacts made must be as large as possible...to try and average out those physical things in testing as much as possible. Even an outside open antenna test range has limitations and variables to deal with.
The idea of just testing one or two contacts, that are cooperating with all the known or perceived variables understood and considered, is desirable, but that severely limits what I think I could do. Locally there are two guys that will cooperate in discussing such results, but every time I request such information from them I always have to consider their possible bias. So, in the boot, I prefer to take signal reports randomly as they come and let common sense work for the viewer regarding any results generated. This is why I put such detailed information for each contact in my Signal Report form, so such likely variables can be considered. Look, I have to guard even myself from being tempted with my own bias...a powerful influence in all humans.
If some don't understand the potential influences reported from a buddie's signal using a beam, a wire, or a mobile...then this stuff I do doesn't matter one way or another. I don't consider this science so why try to make science the point. I claim that common sense considerations play an important role in our trying to understand, and that part of human nature is still alive and well.
Example of the affects of the interactions of RF elements that are close and consideration for how we might tell using our common sense and imagination. Not having a complete scientific understanding of all aspects of the process should not prevent us from exploring the idea, and it might even be a fun thing to discuss with others. That is what I try to do, and hopefully I try to leave out the scientific jargon or issues, if lay words will get the message across.
Example: if we have a beam with elements that are close together and we do what we do to try and evaluate its effectiveness, record the data and then we make a change in the design, would you expect to maybe see the SWR match change, among other things...so-as we could tell such an influence? Probably!
Shockwave has given us an idea to test for similar setups like mine and maybe I'll explore that...which I've never considered. If not for this constructive part of the discussion, such a possibility would probably go untold while we get upset with words, or eating cookies and milk.
Or, if we used an analyzer that simply sees the match in a more revealing light at the same point in the feed line, should we not see similar result changes in the process of checking, or if there were no affects from the change, see the opposite?
Or, if I used some lab quality test equipment and understood its application, should I not also expect to see a more refined determination of the affects noted above, but shouldn't we expect these affects to at least be similar to the less scientific results in a limited way. For me this is desirable, and other's with more experience can tell us if this is bad science.
So, I used my Analyzer presentation above as my approach to answering my own question. Will my Antenna Work Sheet with a bandwidth curve plotted...tell us anything if interaction between my two mounts were an issue. For me this seems a pretty simple approach if it works, and we maybe we don't need a scientific understanding in order to figure out if there is a notable interaction that can be demonstrated easily. I think the proof is always in the pudding.
How say you?
    535A has left the room.
  • @ AmericanEagle575:
