Why oh why am I letting myself get dragged back into this...Some facts need to be pointed out, and some discussion points made...
Below is my Eznec model of DB's Vector without the wires he added trying to prove that the radials had CMC's flowing on them.
You simply removed some of the wires? Really? Those wires were part of what made the model work,
simply removing them will only break the model, nothing more. There is nothing to be shown by doing so.
This ill-fated idea came from DB, Donald, and Bob discussing an article on adding feed lines to Eznec...that I posted from the Eznec Manual. They completely misconstrued what the instructions that Roy Lewallen provided, on the subject for the feed line feature in Eznec, and what it really meant.
This feed line feature was never intended to have wires added directly to the antenna radiating elements. This feature is a feed line coax thing, if one does not let their imagination run away with just words. These guys were on some ill-fated enterprize...where they all had some common belief they were on to something new. DB tells us about all the off line conversations between them in this or another thread on the S4 design.
This is not true. The model came to be before said discussion ever happened. Actually, if you take a look at the date on picture of the initial plot that I posted, you will see the initial model was completed
before that discussion ever happened.
Also, just because that statement was made, that does not invalidate the use of additional wires to simulate common mode currents on that design. You have not, anywhere, explained why such common mode currents cannot exist on this antenna design.
Still further,
no one has demonstrated to any degree that that idea is "ill fated".
I asked DB for more details on his Vector model, the one he started with. The one he also reported early on, an overlay he posted of his unmodified Vector compared to a 1/2 wave, just like I described above in my recant statement.
Yes you did ask for info on a model that I started with. I have news for you, I built that model from the ground up for the purpose of testing the common mode currents theory.
There is no original Vector model to show you as none exists. Also, the very first one I started with
no longer exists. You cannot simply remove a few wires on my posted models to get anywhere close as everything has changed during the process of working with the model, that includes the length and angle of the radial wires, both inner and outer. Any attempt to get to get to an equivalent Vector model without said wires is pointless and irrelevant. You are essentially putting garbage into your modeling software, and you know what the output from such input will be, you mentioned it below.
Maybe DB never intended for his project to turn out the way it did, based on his original idea...which might have had some merit. But, we just can't violate the common sense rules of Eznec, 4Nec2, or any program, and then expect anything reliable to be reported out...garbage in garbage out.
You need to explain how the data that I put in was garbage. You also need to explain what common sense rules were violated. I need more than an opinion here, so links to sources will be required if you want me to pay any attention to what you have to say.
I didn't come up with the idea out of thin air, it was based on accepted antenna theory that is right out of the ARRL Antenna Book, among other places. This data has been provided to you and referenced by Bob85 on any number of occasions.
I have a few notes on the following Eznec models. I imported the model by hand for DB's only model he posted in this discussion. I never ask him for his modified model, I wanted the model he started with...which is represented in the 2nd attached model below. I acknowledge that I also scaled the model to 27 mhz leaving all the dimensions he posted the same. I then changed the units to feet from mm, which for some strange reason he had his model set, but telling me the numbers his model showed is his wire descriptions were actually measured in meters. This took a lot of figuring and DB refused to answer questions from me at some point.
One model I posted? The fact is I posted two... Have you not seen the second one, which was modified for aluminum, and posted with a plot, current table, and phase data? All of this data are in the same post, although the gain data is inaccurate, but then you are a modeler, I'm sure you can figure that out and why, and what it should be...
So you did adjust for size good, you did something right... Why did you need to adjust for size, why not simply use the frequency that the model was designed for, less chance of errors and easier to accomplish.
Also, why is it strange that I choose to use meters to design my models? I can use either system equally, and I personally think that meters is easier for me to make models with. That is my opinion based on first hand experience, and if you think that is something strange then I could just as easily ask why someone would use the imperial system to design their antennas over metric... In the end such things are pointless and distracting, nothing more.
This does get complicated, trying to explain, and it will be hard to understand, but IMO DB' modified model tells us nothing about how the cone works...much less help us understand how the S4 design works.
Really... Have you not seen the several anomalies I noticed in both models, some of them I posted in said thread. You never talked or even mentioned any of them. There are other anomalies as well, but by then it was pointless continuing the discussion. Perhaps I'll revisit the model at some point, but I doubt I'll make any findings public. And, en the end, even if the model is shown to be completely irrelevant to the Vector design, the model is still relevant if only because of the anomalies I noticed. There is an avenue to me to learn more about NEC2 modeling, and perhaps antenna theory itself.
Also, I think I've shown actual evidence of something that Bob85 mentioned several times, of course, you categorically disagree with that theory of his, even though it is published in one of the most reputable source books on antenna theory in the history of the theory...
The 1st model below is the model that DB posted...where I had to fix things to make the model work. I imported his wire definitions by hand. In order to get his model to work even close to being correct...I had to change the important wire diameters he used from .0001 m, to .50" inch. Most might agree that a .50" inch is close to a bare minimum for real antennas that use aluminum tubing in the real world or with modeling. The diameter he used is way too small even for wire antennas, and its use will generally not produce good results in modeling at these wavelengths.
DB this antenna model is for a radio antenna not a precision watch.
The second model is the actual model he posted without my fix.
The 2nd model is before I changed the wire diameter.
See these models below.
I was not trying to build an antenna from the model or I would have used thicker elements. This, however, does not invalidate the model, it simply would need to be adjusted for the thicker elements, that is all. To say anything else shows, with all due respect, a distinct lack of understanding of antenna theory.
You choose to use a different diameter simply, well, because you wanted to? And it wasn't even close to the original? Did you make any further adjustments to account for this discrepancy you introduced into the model? Actually, don't answer that, I can already tell you the answer to that is no, if you did you would have noticed at least two of the anomalies I noticed when it comes to adjusting the dimensions of the model.
A note about your .pdf file. You note an error message. Did you ignore me addressing the error message that came up, and explain it on more than one occasion? I talked about the error message, and and how small the differences were from a version of the model that didn't have it. I also clearly pointed out, on more than one occasion, that the error message itself was in error. To say the elements have unequal segmentation when the wires in question were exactly the same length and had exactly the same number of segments? Also, if you bothered to take a look at the second model I posted, the one that was modified for being aluminum, the error message was corrected and no longer exists.
In conclusion, I need more than your opinion on why this idea is an:
You have put forth opinion as fact on this matter, now you need to back it up. Again, I need reputable sources, and words from you simply do not count as such. I'm sorry but your reputation proceeds you.
And finally, Eddie,
did you really think I was going to lie down and let you trash my work with nothing more than an ill-informed opinion that you spout as absolute fact? The fact is I left the discussion because of you Eddie. And it wasn't your criticism that caused it. It was saying things were wrong before you had anything to go on, asking questions that if you bothered to read what I have posted you would not have had, and other crap like that, and that isn't a complete list.
Now I find myself having to defend myself against you and an opinion spouted as fact? You claim you want to know how this antenna works, and that is fine, but you will
NEVER get there by doing crap like that.
The DB
