What is the mast diameter for a Imax 2000 and what is the best height to run it at? I am on flat ground with few obstructions, I have access to all the steel pipe I want, 1" thru 6". I plan to make a tripod stand on the ground and then go up from there. It will be right up against the back wall of my house, It will be braced to the house @ about 13'-0" off the ground, so what is the minium height to work well and not be too obtrusive.
Thanks
Jerry
Thanks
Jerry
