Maverick A-24 Info needed!
Lonewolf
Nov 2, 2010
2
57
I have recently installed a Maverick A-24 with a X-Force 400 Amp pushing. Also using a Astastic D-104 mic and a steel whip. Does anyone have good reviews of this set up and have any recommendations! I would appreciate any info. There is a bunch of knobs for me to set! Thank you guys for any help!
Magnum Maverick A24
Should be pretty straight foreward. Set the RF gain wide open, nb/anl on, 10kc off, mic gain at 2/3's, variable power where ever you need it for the amp. The AMT control (all mode talkback) is a volume control for your talkback , you can set the echo as well by listening. That should be it.
