$175 shipped
maxlog M-8800, used in my suv for the past 8 months, most stable ssb radio I have used in the mobile, no matter what the temp its on freq and ready to go without messin with the clarifier, just lookin to make room to try out some of the new radio's coming out this fall. original mic and power cord never even used, here are the specs:
M-8800
MAXLOG M-8800 28.000-29.700MHZ MOBILE RADIO25.615 to 30.105mhz
Specifications:
Item Number : M-8800
General:
Frequency 28.000-29.700MHZ (25.615-30.105MHZ)
Frequency Bands A/B/C/D/E/F
Channels 40 Channels(programmable)
Frequency Control Phase-Locked-Loop Sypthesizer
Frequency Step 5Hz-100Hz-1KHz-10KHz
Frequency Tolerance 0.005%
Frequency Stability 0.001%
Temperaure Range -30℃ TO +50℃
Micrpphone Plug-in Dynamic with PTT/UP/DN/ASQ switch and coiled cord
Input Volyage 13.8v normal/15.9V max. /11.7 min.
Current Drain 5A(TX AM Full Mod.)/9A (SSb 30W PEP)
Size / Weight 28 x 26 x 6 cm/2.8Kg
Antenna Connector UHF,SO239
Transmitter:
RF output power 1-12w AM/CW (adjustable)
2-40W FM (adjustable)
0-30W USB/LSB(adjustable)
Modulation High and Low level Class B
Amplitude Modulation:AM
Varied Capacitance Frequency Modulation:FM
Inter-modul. Distorsion SSB:3rd order, more than -25dB
5th order, more than -35dB
SSB Carrier Suppr. 55dB
Unwanted Sideband 50dB
Frequency Response AM and FM; 450 to 2500Hz
Impedance 50 Ohm, unbalanced
Receiver:
Sensitivity (12dB Sinad) SSB:0.25μV for 10dB (S+N)/N at greater than 1/2W of audio output
AM:1.0μV for 10dB (S+N)/N at greater than 1/2W of audio output
FM:1.0μV for 20dB (S+N)/N at greater than 1/2W of audio output
Sensitivity AM/FM: 6dB at 3KH/ 50dB at 9KHz
SSB:6dB at 2.1KHx /60dB at 3.3KHz
IF Frequency AM/FM: 10.695 MHz 1st IF,455 KHz 2nd IF
SSB:10.695MHz
Adjacent Channel 60dB AM/FM / 70dB SSB
RF Gain Control 45dB adjustable for optimum signal reception
Autom.Gain Control (AGC) Less than 10dB change in audio output for inputs from 10 to 100,00μV
Squelch Adjustable;threshold less than 0.5μV.
Automatic Squelch Control (AM/FM only)0.5μV.
ANL Switchable
Noise Blanker RF Type, efecctive on AM/FM and SSB
Audio Output Power 4W ito 8Ohm
Frequency Response 300 to 2800Hz
Built-in Speaker 8 Ohm , round.
M-8800
Specifications:
General:
Transmitter:
Receiver:
SSB:10.695MHz
ANL Switchable
