I have a lot of noise coming from a transformer. It's so bad at times I will get up to a 9 s-unit buzz. There is no way to even listen to an AM broadcast station. And yes, I've called out PG&E three times...but there is always no problem. I've even taken a portable AM/FM radio, walked up to the transformer with the PG&E guy showing him where the noise was coming from, but the same story, no problem.
I ordered the "MFJ-1026 1.5-30 MHz Deluxe Noise Canceling antenna" from HRO to see if it would help. It's not an antenna to transmit on, but to pick up the RFI and null it out before getting into your radio. It's not supposed to act like one of those "Noise Choppers" in-line things that are no more than turning down the RF gain. You can see it and read the manual about it at
http://www.mfjenterprises.com/products.php?prodid=MFJ-1026.
Anyone ever tried one, or something like it, or knew anyone that did? What were the results? Does it sound like it might work?
Thanks,
Mr Gnome
Thanks,
Mr Gnome
