I have an MFJ 259b meter that I use to check the swr's on my cb antenna's, my question is just how do you get the r= and the x= down to where you want them?
It is just fine for a mobile antenna, too. The point was that there is less ability to manipulate a mobile antenna so that the X=/R= can be brought into line with the lowest SWR.
Although it isn't extremely accurate, that 'little gadget' has many functions and abilities. Accurate enough for Hams and CBers. Exploring the manual might amaze you. Not a bad piece of gear at all - if one considers what it sells for.
I've only needed to use about a half dozen of its features so far.
I would say its OK for the serious ham as well. That is unless the serious ham has large amounts of money to spend on a Rigexpert. I feel that the difference in possible accuracy will not be seen when the antenna is in use.Its ok for a casual Ham and CBer. if you want better then you'd better be ready to pull out the wallet!!! :tongue:
