Mic Problems
A
Adenfan48
Guest
I have a HighGear power mic. Tonight when i was driving around i was trying to talk to a trucker. He said i had a really bad squeal. He said it sounded like i swollowed a wistle. Whats the problem? I have the power on the back set at 3.
Cobra 29 LTD classic tuned
I Max 99
& Snowcap Amp built by Radio Doctor!
Cobra 29
Cherokee Niterider 150
Pro Scanner 2030
Realistic Navaho 458
</p>
I Max 99
Cobra 29
Pro Scanner 2030
</p>
AdenFan,
Sometimes that happens if a wire came un-soldered in the connector and is touching something. Also I have heard a squeal if the srw's skyrocketed sometimes when the coax was lose.
</p>
AdenFan,
</p>
The stock mic i had that came with the radio also had a soldering problem with it. Thats the only reason i bought the power mic. I moved the antenna today i might not have tightend all the wires up. Ill look into it more! Thanks
I Max 99
Cobra 29
Pro Scanner 2030
</p>
I Max 99
Cobra 29
Pro Scanner 2030
</p>
    those boys in Louisiana going to be hard to live with...working those HI stations...my buddy Greg KK5SW/4 elements @35ft/350 watts...2 HI contacts today!!!! Arnold KE5JXC snagged one also!!!
  • @ Mark Malcomb:
  • @ Naysayer:
    I’m
