Mobeam
I like it, Jeff. (y)
But rather than a vehicle, I’m thinking of a backyard project using portable work light stands or tripods. :giggle:
Still not clear on now the elements are connected to each other (if they indeed are). :unsure:
Whip #1 and #2 are grounded whip#3 is hot ( hook up as normal) whip #4 is grounded.
Now you know where the key down crowd learned to build shootout set-ups.......
the one at a key-down the rear is grounded then the main antenna is connected to coax then depending on the number of director elements are floaters not grounded if i remember correctly
The directors can be grounded or isolated as groundwire posted just like a Yagi.
Most also use fighting sticks not loaded antennas but there guys that run all kinds of antennas.
Then Sha-Sha rolls up...
lol, yea, sha sha's van. that was something else. it's almost hard to make sense of the thing lol
Reactions: AudioShockwav
  • @ Geoexplorer69:
  • @ Geoexplorer69:
