currently have a 102" with spring in the middle of toolbox behind cab of my truck. would a wilson 1000/5000 mag mount on roof be a better choice?
here's what i think:
the wilson would be up higher and clearer without cab blocking some of the signal, stinger shouldnt lean back as much as 102", bigger ground plane on top of cab.
the 102" is doing me a fine job, just looking for an improvement. i figure if mounted in the same place the whip will win but not sure if i want to get a quad mount and put the whip on top off my cab (should wack everything in sight)
