i installed a Monkey Made Mm9 on my Dodge Ram pickup. I mounted it in the center of the bed behind the rear window with the coil above the roofline. On my MFJ 259 it came in resonant at 25.200. Check the grounding and had good continuity. Thought maybe it was having interaction with the cab, so I moved it to the rear of the bed ...same thing. But when I touch my hand to the base of the antenna(stud mount) and the mount the SWR drops in perfect. Any ideas?
