Mobile antenna setup, right or wrong, help me fix it.
HomerBB
Jan 4, 2009
3,941
2,683
273
69
Rogers, Ar
What I'm doing here is writing down some thoughts for a hypothetical center loaded antenna that is mounted on a stake hole mount on the front right of the pickup truck bed. The best SWR obtainable here is 1.3:1 on ch 1, 1.6:1 on ch 19, and 1.9:1 on ch 40.
What I'm hoping you'll do here is correct any wrong thoughts in the paragraphs I've supplied. It will be acceptable if you copy and paste it into your comment box and make changes to the paragraphs. Additional corrections by others could do the same as we go. Additions to the core paragraphs will be fine, adding more information to complete the scenario and reach a reasonable consensus for this hypothetical setup. When disagreement occurs some debate back and forth is allowed for a while, then a compromise of terms that reflects honest theory will be put in place from the debate. Maybe this can be done without name calling, flaming put downs. I feel I am taking some considerable risk going out on a limb exposing my thoughts to scrutiny, and corrections. I hope you'll participate. Thanks everyone.
Ideally, when possible, the coil on a mobile antenna should be set as near to the center of the shaft lengths as mechanical and aesthetic considerations will allow. When the coil of the antenna is mounted below the roof height of a vehicle the placement of the coil is effectively reduced to much less than approximately half the combined shafts height. MOST of the radiating power occurs from the bottom of the coil upward. The longer the upward part of a loaded antenna the closer it resembles a non-loaded 1/4 wave whip, and the better your TX/RX. So the idea of getting a longer whip could help when the mounting position is less than optimum, or below the topmost height of the vehicle, but may not necessarily correct an SWR due to the lowered coil height in relation to higher part of the vehicle body, or reflect from the vehicle body. Although the placement in the center of the bed rail behind a pickup cab (or on a toolbox) does not raise the antenna up completely above the cab, it does center it on the truck body. This can help with the reflect, and even out the radiation pattern some. The ground effects from the earth beneath the truck is the true groundplane, the truck is simply the mount, and functions as a part of your antenna system; that's why good grounding to the vehicle is needed. The vehicle body influences performance, and it is in your best interest to USE it to your maximum advantage. If not, it will serve to your disadvantage. We often place antennas where we can, but trade offs in performance are always in play. I suggest finding a way to raise your antenna up high if you cannot put it on the cab itself.
The funny thing about mobile antennas like this is that more than SWR changes when we make alterations to the design. The way an antenna is built decides its performance parameters, but every install changes those things, and SWR only tells us the reflect is controlled. SWR is an important measurement, particularly if you are running high power, and having a low SWR helps to prevent damages to equipment. That said, SWR doesn't tell the whole story of an antenna's performance. It actually tells less about the performance of the antenna then we think. It speaks to the match of the antenna system and the transceiver. What I'm trying to get to is antennas are usually designed with the optimum performance in mind, and as a result it's expected they are to be mounted in the optimum location to take advantage of the design. Changing the SWR may even make your antenna perform less well if you aren't changing the antenna setup in ways that make it work best. It can be assumed your SWR is high because of where it is located on the vehicle. An SWR solution could be either getting a longer riser to raise the coil up, or a longer whip. You will by these methods reconfigure the shape/design of the antenna. So, leaving the antenna where it is, yet bringing down the SWR may only make us feel better about things, but the antenna is still not in the location for best performance. In fact, it is now actually a different antenna. Likely, it will not hurt the equipment; reflect is better controlled (maybe). But he antenna was designed to be installed differently.
I see lots of people struggle to mount these longer center loaded antennas on pickup trucks in less then ideal locations to limit their driving height. If you have to move the antenna so that it's way off center on the ground plane, not mounted directly on top of a ground plane, or significantly blocked by having the cab parallel to it, you may be doing more harm then the larger antenna can correct.
You are likely to find a shorter 4 or 5 foot whip on the top of the cab does better then a 6 or 7 foot whip a foot or two below the cab roof. Especially if the ground plane is compromised in the longer antennas mounting location. I'd always opt to put a 3/8 mount on the cab. Buy whatever length loaded antenna I could get by with driving around and keep a full length 1/4 wave in the bed for parking and talking. I doubt anything practical would work better in a single antenna and the cost of this system is attractive.
... The best SWR obtainable...is correct any wrong thoughts... correct an SWR due to... SWR changes when ... SWR only tells us... SWR is an important measurement...a low SWR helps... SWR doesn't tell... Changing the SWR may... SWR is high... An SWR solution... the SWR may... [/B]
methinks you worry too much about VSWR:bdh:
Perhaps. The situation is hypothetical. I am just putting info in it to help see it. I think most folks are concerned with SWR. Reading the post took a few seconds. Getting an antenna setup can takes minutes, or hours, and tuning for best match can take several minutes, or hours even. So no matter how concerned one appears not to be over SWR, they spend a great deal of time not necessarily talking about it, but working on it.
I don't own a p/u truck.
Road Squawker brings up a point about SWR over-emphasis. So I read back over the hypothesis and realize I left something out. This operator wants to run at least 500 watts on this system. Does the addition of high power into the hypothesis change the need to emphasize he best match to the antenna system or not?
A hypothetical center loaded antenna that is mounted on a stake hole mount on the front right of the pickup truck bed. The best SWR obtainable here is 1.3:1 on ch 1, 1.6:1 on ch 19, and 1.9:1 on ch 40
There will be a 500 watt kicker in the mobile.
Anything else? If no one finds anything that needs correcting, or saying better in all this I'll have to assume it is correct throughout.
Are you writing this for yourself I thought ? Sounds like you are writing it to answer someones question not of your own. But i am confused because you made the below statement then you even say you dont own a p/u truck, i guess the truck is hypothetical too? .
"What I'm doing here is writing down some thoughts for a hypothetical center loaded antenna that is mounted on a stake hole mount on the front right of the pickup truck bed. The best SWR obtainable here is 1.3:1 on ch 1, 1.6:1 on ch 19, and 1.9:1 on ch 40."
I know of some one who asked me about all this. He owns a p/u truck. His situation was fixed to his satisfaction, but I still wondered if the parts of the situation I tried to put into the scenario as I recalled it were accurate. So I asked it here as a What If sort of thing.
Is the reasoning sound in the scenario/hypothetical setup, or is something wrong or missing in it?
Sorry to confuse.
"Ideally, when possible, the coil on a mobile antenna should be set as near to the center of the shaft lengths as mechanical and aesthetic considerations will allow."
"MOST of the radiating power occurs from the bottom of the coil upward.
those two seem to go against each other . if "The longer the upward part of a loaded antenna the closer it resembles a non-loaded 1/4 wave whip, and the better your TX/RX" why should the coil be in the middle ? if......the lower the coil the longer the "more upward part" is correct ?
not arguing . just clarifying .
Exactly what I was hoping for, Booty.
I have these elements in the scenario because I've come across the ideas in a large variety of undocumented resources over a great period of time.
My guess for why these two ideas co-exist is that the center loaded coil at near middle of the shafts result in the putting the radiation where it needs to be. Once done, the work of the longer whips is best put to work.
Perhaps what I'm trying to say is once the work of a properly built and placed coil is done the antenna still needs additional characteristics to maximize its efficiency.
Maybe the more enlightened will get in here and help sort some of this out for novices like me.
Sorry to confuse.
NP. i was confused because it seemed like you were talking to yourself LOL... With out getting into all the particulars i would put a firestick in the bed pocket the tallest one he could find 7', they are top loaded, unless he wants to run alot of watts they work pretty good.
