I've had two of these fail within the last year and the conclusion is the center female on the stud mount gets weak and doesn't fit snug enough on the pl259 center pin. Hope that makes sense... The reason I'm figuring is that there are no notches on the 239 connection of the stud mount so the 259 outer connection isn't flush causing the the connection to give. Make sense?
Why would they make these without grooves or notches for the pl259? A chassis mount 239 has notches, the back of our radios, amplifiers and so on but not these. Makes no sense.
I'll file some notches in and see how that works.
I know this has come up before so hoping for some insight.
