Now read that post again. This isn't about a 102" whip, but a loaded antenna.
On second thought, it would apply to any antenna, loaded or not. If you add length to a 'tuned' antenna then you can expect it not to be 'tuned' any more, you changed it's length. It has nothing to do with the spring being a 'coil' because of the shorting strap inside.
maybe if you'd read the first sentence instead of leaping in trying to make me look wrong, you'd have realised i knew it was a loaded antenna,
as i said, " it depends on the antenna"
then i went on to explain how it affects a whip that's physically too short, which most US cb'ers are familiar with, to show that if he uses a resonant i.e. tuned antenna, adding it will make it too long and detune it.
So like i said, "IT DEPENDS ON THE ANTENNA".
If your going to nit pick, do it with someone that doesn't know more than you
and I was the one who mentioned the shorting braid which does affect it. The coil is shorted out by it.
I don't even know why I argue with you, you still haven't figured how a swr meter works despite being told by several people, hundreds of times, you might baffle others with bullshit, but i'm a wee bit more clued up than most people
:headbang:headbang:headbang
