Today I finished putting together a model of my Ford Explorer. These are the results from said model.
First, this is what the model looks like with a 1/4 wavelength antenna on the middle of the roof.
I have three models based on this object, one with the antenna on the middle of the roof, as pictured above, one with the antenna on the middle back of the vehicle, and one with the antenna about where it is on my vehicle, which is between the other two. I also have a model of a 1/4 wavelength ground plane antenna with horizontal radials at the roof height.
The vertical plot (the pattern as seen from the side of the vehicle), the front of the vehicle is to the right (the 90 degree mark) of this plot.
The horizontal plot (the pattern as seen from above the vehicle), the front of the vehicle is at the top (the 90 degree mark) of this plot.
The antenna mounted on the middle back outperformed the other antennas in the forward direction, including the 1/4 wavelength groundplane reference. My setup is, not surprisingly, between the center and middle back mounted antennas as far as forward radiation goes. As is expected, as you move the antenna towards the back on the vehicle, the pattern shifts more towards the front. An interesting thing to note is the antenna mounted on the middle of the roof actually has more gain to the back of the vehicle than the front, bot not so much that you will notice.
Any other thoughts on these plots?
I do want to add more vehicle models in the future. As it is a lot of work to make one of these models, I'm not sure when that might be...
Here is a link to the .NEC file I used if you want to play with it.
The DB
The DB
