Modified Trucker 5000 for Ham band
fasteddy
377
2
26
OK, here is what I would like to accomplish. Take my Trucker 5000 and add shaft and stinger to make it work on 15 or 17 meters. I did some research and found that the coil is equal to 53 inches of antenna. So if I use the 22 inch shaft, the coil (which is 53 inches), and a 58 inch whip I would have 133 inches of antenna, (1/4 wave on 21.375), in a 80 inch antenna. Did I figure this right or do I need some more help here<img src=http://users.joplin.com/dutch64804/posticon60.gif ALT=":60"> ? I guess the question I also have is, do you add the length of the shaft in to the lenght needed? Is that a confusing question or what?<img src=http://users.joplin.com/dutch64804/posticon5.gif ALT=":p5"> Or could the use the 36 inch shaft and a 63 inch whip for 17 meters?
<img src=http://users.joplin.com/dutch64804/posticon58.gif ALT=":p58"> in advance
Ed
KC0PZE
</p>
Hello Fasteddy(how ya been?) I think he wanted you to see the formula at the bottom....
For frequencies other than those listed above, use the following formula:
468 ÷ F = ½W
½W ÷ 2 x 12 - C = Whip Length
WHERE: F = Frequency desired ; W = Wavelength ; C = Coil Factor
(Coil Factor : for W-1000 use : C=41.65 ; for Trucker 5" use: C=52.21 ; for Trucker 10" use C=53.84
The lengths calculated will be an approximate starting point only. Trim for best SWR.
CDX 339
RadioActive
</p>
    535A has left the room.
  • @ AmericanEagle575:
