Modulation Meter from DAK IX to work with Cobra 2000gtl
Crambone
Jan 22, 2019
519
160
53
56
I have a modulation meter from a DAK IX that I acquired in an enclosure, what it was for I have no idea. My question is can I hook it to my 2000 gtl to view modulation with my 2000 gtl in Power out or SWR?
Drew
Don't know, but if the coil in the mod meter is the same as the S-meter, you could have a problem. Using the DAK's S-meter with a Cobra 148GTL circuit board required a buffer amp to drive the DAK meter coil. Connecting it directly would only get deflection roughly a quarter of the way up the scale with the trimpot maxed. An op-amp chip took up the slack just fine.
Had a schemo of the buffer amp we used somewhere around here. Been a few years.
