And if you re-read my statement
@groundwire ...
You'll see that the effort of my post is not to truly "Bash" Yeasu - it is really from the lack of consideration from the radio manufacturing umbrella of companies - this puts Yeasu inclusive, for the backing of their products knowing their shortcomings in efforts of durability on the field.
IF you produce a lemon, try to make lemonade - Keep producing Lemons the problem with that is, you will run out of sugar eventually.
Or perhaps learning not to change horses in mid-stream - not a good idea to struggle against strong currents while underway equates the Thru-Hole versus SMD argument; Discrete's gives the field tech the edge in getting back up and running far faster than to pay up front shipping handling only to get it returned with a note saying could not recreate condition of customer complaint - with it being returned in the same condition You wasted a radio, field day ,your time and money - for a bitter wheel - chock ending.
Understand that the construction of ALL said equipment is not in question. the Quality of effort put into them to keep their reliability - when they use a different method of assembly and their failure to back their warranty on it - is.
My beef was/is with the SMD versus Discrete - the changeover without truly testing or providing the service level needed to overcome said problems with earlier generation SMD equipment - was, and is,
VERY evident - as if they knew a problem was going to occur.
