Mr. Coily
I used one of his older coil antennas years ago, before he started adding capacitance hats to them, it worked fine.
It is another coil antenna, lots of guys have used flat stock for the coils, use the Search Forums link above and search for boomhauer antennas or monkey made.
Some claim that the flat bar provides more surface area than a tube.
Measure the thickness, width and length of the flat stock used in the coil and use one of the online calculators like this one:
http://www.onlineconversion.com/object_surfacearea_box.htm.
Then get the OD of the tubing and the length of the coil and do the same thing.
Compare the surface of the flat stock with the round tube.
There are a lot of factors that affect how well a coil can work, but it in the end it is still a loaded antenna.
You are not going to see a monster increase in field strength or gain between say a 10K antenna vers his antenna or another loaded big coil antenna of similar length.
Dan was calling the crossed circles on top of one of his antennas, "Audio Balls" at first,
Lol, He got a good ribbing over that if I remember right.
He is a good machinist and is well know up in the north west corner.
Reactions: hotrod
I run a dual hot setup his Enforcer Comps on my mini van build quality is better than any other antenna prices are a little high for his antenna but they work pretty good
thanks guys. iu was looking at one of his newer one with the cap on top .
the roof of my van is about 8-9 feet so i was getting curious about his
newer antenna called the punisher.
Oh heck...You don't have to stick it on the roof....Stick'em on the rear quarter panels!:LOL::ROFLMAO::eek::whistle:
Reactions: hotrod
I would see if you could get that antenna with the top cap if it snags a tree branch it will break your antenna or mess your roof up
    535A has left the room.
  • @ AmericanEagle575:
