Over the weekend, my TH-D72 went for a swim in the river. It had a mind of it's own and took a dive from my vest clip into the river where I was bending over to pick up something in the water. I didn't think much of it because of it's "water resistant" rating. I picked the radio up, blew off the water and continued to use it for the rest of the day without a problem.
Later that evening, I turned it off, put it on the charger and went to bed. In the morning when I picked it up, the battery indicated that it was fully charged (the charger lights on the radio had turned off) but it would not power on. I plugged it back into the wall wart and tried it - it powered on fine. Well, I thought maybe I didn't charge it correctly, so I plugged it back in and came back in several hours. It still wouldn't turn on when on the battery power.
I put the battery on a multimeter and it tested at full voltage. At that point I got out the manual to find out how "water resistant" this radio really is. Unfortunately, I found the big bold warning about submerging the battery. Since the radio seems to function fine on the wall wart, I figured that I had done something to the battery and ordered a new one. When the new one came in, I attached it to the radio and plugged it in to charge. The complete charging cycle appeared to work, but the radio still will not power on under battery power.
So, now I'm trying to figure out where to go from here. I have one suggestion to try from the TH-D72 yahoo group, but if that doesn't work I might have to send it in for repair
The lesson here is that the TH-D72 is not waterproof, so don't dunk it in a river.
