My setup can be yours.
BammBamm
Instigators ...173 on the southside.
May 24, 2010
625
304
93
51
Steger,Illinois
Voyage V9000 expanded 10 meter radio with endless echo mod and both single and 5 tone beep installed all done with the stock switches no added crap or holes and has been peaked and tuned. comes with both stock mic and a chrome RK-56 , 50 foot of Belden LMR-400 coax with ends , 20 foot of antenna mast with ground wire , Imax 2000 base antenna , and a Pyramid 15 amp power supply. Forced to sell <proof> asking $325 for all of it and I can't ship due to the size and weight of all of this. I am in the 60475 zip code south suburbs of chicago. I am not going off the air just agreed to sell this before I buy another radio.:thumbdown: All of this is about a year old and I can show it working. If you have talked to me on the air in the last 7-8 months this was the radio I used.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
