NCX-5 National Transceiver
FYI you can download a pdf version of the manual at bama.edebris.com/download/national/ncx5/ncx-5.PDF.In the meantime, it uses a three conductor 1/4 headphone type plug called a TRS for Tip,Ring,Sleeve.The sleeve is the ground for the mike audio and the PTT ground.The tip,or very end of the plug is the TX line.Connect it to ground to TX. The Ring connector is the mike hot audio connection.
