That is Crazy..
I have been in 80 to 100 mph winds..
Nothing like that though..
Another good place ( if and only if you have the time to do so & this is if you are stuck outside without the ability to get to a secure basement or underground structure ) is to go to a major highway over pass..get out of your car/truck/motorcycle and quickly run up under the passage way where the under carriage of bridge starts to angle down to lower street...Wedge yourself under in center section.
It is likely as safe an area you can find if stuck outside on the street
(unless you can get to a safe and secure basement or storm structure)
