I was asked by Henry HPSD to confirm the ground wave accuracy of NEC2 based models (such as 4NEC2) before I start reporting information based on it. I've done some research and found that there really isn't much info on it out there.
Henry has used (or has at least referenced) EZNEC Pro to me and publicly in the past. Assuming this is a basis for comparison of accuracy this is the information I have found on-line that has information on this topic.
I'll start with Cebik and a quote from this page:
This was found in the NEC4 portion of the page for EZNEC Pro, and as it is suggesting that EZNEC Pro is using the NEC2/NEC4 code to generate ground wave data, this would suggest that the ground wave data from other programs that use NEC2/NEC4 data would be just as accurate as EZNEC Pro.
Next on this page we have this quote:
Again, NEC2 data is being referred to along with the EZNEC Pro data for ground waves.
Finally I have this quote from this page:
This again specifically states that NEC2 ground wave data is accurate.
Does anyone have further information in regards to NEC2 and ground waves? Anything that shows it is accurate, or inaccurate?
The DB
Cebik said:EZNEC also implements the NEC2/NEC-4 ground wave (RP1) output.
Roy Lewalle said:This can be easily verified by running NEC-2 with ground wave analysis enabled, or with EZNEC pro if you have it.
fmradio said:The groundwave fields calculated even by a suitable NEC2 model of a real-world, AM broadcast monopole system using buried radials closely can duplicate the fields accurately measured for that real-world system by a professional broadcast engineering firm using a calibrated FI meter (link below).
My NEC2D calculations are shown at the top of that graphic, and are based on the physical conditions generating the real-world, measured results shown at the bottom of that graphic.
The DB
