hello to all
i'm having an odd problem with 1 of my radio. here is the problem with my 29 classic my reflect on my box is ok with my 25 classic it is also ok no issues but when i run my 148 gtl philly made i have a higher reflect 29,25, relect=5 watts on a 600 watt dead key
with the 148=12 watts then it starts to creep up a little. tech look at the box no issues found check coax no issues found. clean all ground. no luck
