Thanks alot will try, this radio swrms sit at past red and dont move very strange.jess you adjust the antenna, not the radio for swr.
trying to find a pic of the radio so I can see what you have but not having much luck
find the swr / Cal switch and set for calibrate.
key the mic and turn swr calibrate until it's @ 100%/SET marker.
reset the first switch to swr and key the mic.
meter should read current swr setting
hope that's whet you were trying to find.
ThanksIf the meter in the radio isn't functioning you might need to put another SWR meter in line I really don't trust the meter on the radio anyway but it will usually get you in the ball park .JMO
