first i thought i blew the tubes ...5-6lq6 in this ..until i took a closer look.when i turn the load control it makes the connection at the tune control start to flame up.it will flash sizzle and spit flame .......thought maybe bad solder joint so i resoldered it all ...still the same ....then i was told the caps in the strip that hold all the cap wires...pulled them and they were ok...not shorted.didnt know how to check the choke but when put on the ohms meter it would make the meter buzz...like dead short i guess...but this is a choke so i dont know...the choke is unmarked.the caps were .001m 3kv..2 of them .the tubes are all ok...i can even get a little power out but if i try to dial up too much load the tune control will flame up at the connector .....help...........any ideas?this is a transel nitro 300 with 5 6lq6's.....this beast was swinging 800 befor all this happened..just seen a flash one day....could the load n tune controls need replacing??
