I have a few questions for a project antenna build. First, I'm going to build a two element beam using 13 ga. wire on a pvc frame. When using wire, is it necessary to remove the shielding from the whole wire? If so, would a clear enamel be a good choice to coat the wire for protection? I will also use a balun for the feed point. Is the balun calculated as part of the wire length to keep the correct frequency? Last question, how is the swrs adjusted when using a balun? Any info will be greatly appreciated. Thanks.
