Need Palomar ssb500 info
S
sme89saulito
Guest
Hi
i have some questions:
First I want to know if anybody has information about the palomar ssb500 or hystar100 like transistor voltaje chart, because i have a hystar 100 burned by connect inverted voltage without fuse, already i have changed all components that i have checked and found burned, but the radio still no rx and not tx.The only difference between the hystar and the palomar is the pll hystar uses the lc7120 and the palomar is mc145106.
The components that i found burned are:
Ic6 78l05 pll voltage regulator
Ic4 upc1186 af power amp
Tr23 2sc710 at mic preamp section
D23 at mic preap section
Tr4 2sc710 rx rf amp section
D1 rx rf amp section
I have unsoldered all the transistors and diodes at the rx section, and mic preamp section and check with the multimeter, found that all are good.
The section of pll, vco and mixer i think that is good, because i have measured the freq at TP8 L16, and are the correct for am and every channel on tx and rx, for usb and lsb i dont have measured it.
At rx section, I have measured at IC4 af power amp pin 4 and there is not signal, the frequency from VCo to the first mixer FET1 3sk45 is ok, because i have measured it for every channel, i replaced the fet thinking that it was bad, but the result was the same, when i tune the radio in a channel and i transmit with other radio, at the same channel, the needle of the rx meter, just has little deflection and also there is no signal at IC4 input pin 4, the results is the same with nb/anl switch active or not active.
At tx section, the frequency for AM is ok at fet6 2sk33, for usb and lsb i have not check it, but also there is no signal present at Ic4 input pin 4, the strange is that the signal at mic preamp input IC3 pin 2 (upc592h2) is too little, i think that the transistor between the micro and preamp ic are attenuating the audio signal, because if i lift the TR18 base the audio signal is great,and the audio output of IC3 pin 6 also is great, but the signal at ic4 audio amp still too attenuated, but i have unsoldered tr17, tr18, tr19, tr20 and diodes of this section, and i measured it with multimeter and it is ok, so maybe the signals that control the transistors is bad.
I want to know if somebody have measured with oscillocope the signals after the rf amp or preamp at rx section of any radio that uses the same configuration of the palomar ssb500, because i dont know how it should be, or how i can check that the rf amp is good, also if somebody know which is the impedance between input and output pins of one 7.8mhz cristal filter, because mine measured 0 ohms.
The schematic is here:
www.cbtricks.com/palomar/...00_sch.gif
Well i hope you understand me, because i dont know very much english i'm at Monterrey Mexico.
THanks
En español por si alguien sabe y habla español
Hola
Quisiera saber si alguien tinen informacion acerca del radio palomar ssb500 o el hystar 100 algo asi como la tabla de voltages de los trasistores, ya que tengo un radio hystar 100 quemado ya que le conectaron el voltage de alimentacion invertido, pero no tenia fusible, ya le cambie los componentes que yo le encontre quemados, pero el radio sigue sin transmitir ni recibir.La unica diferencia entre el palomar ssb500 y el hystar 100 es el pll el hystar usa el lc7120 y el palomar usa el mc145106.
Los componetes que encontre quemados son:
IC6 78l05 reg de volt seccion pll
IC4 upc1186 audio power amp
Tr23 2sc710 seccion preamplificador del micro
D23 seccion preamplificador del micro
Tr4 2sc710 seccion de recepcion amplificador de rf
D1 seccion de recepcion amplificador de rf
he desoldado todos los transistores y diodos en la seccion de recepcion, y la seccion de preamplificador del micro y los medi con multimetro y miden correctamente.
la seccion del pll vco y primer mezclador pienso que estan bien, ya que he medido la frecuencia en el tp8 L16y estan bien para am y en cada canal en transmision y recepcion, para usb y lsb no los he medido.
En la seccion de recepcion, he medido en el pin 4 del amplificador de potencia de audioy no hay señal presente, la frecuencia del vco hacia elprimer mezclador fet1 3sk45 es correcta, porque la he medido para cada canal, reemplace el fet pensando que estaba malpero el resultado fue el mismo, cuando sintonizo el radio en algun canal y transmito en el mismo canal con otro radio la ahuja en el medidor de de recepcion solo se mueve muy poco, y tampoco hay señal en el pin 4 del ic4, los resultados son los mismoscon el switch nb/anl activado o desactivado.
En la seccion de transmision la frecuencia para am es correcta en el fet6 2sk33, para usb o lsb no la he medido, pero tampoco hay senal presente en el pin de entrada pin 4 del ic4, lo extrano es que la senal de entrada del preamplificador del micro Ic3 (upc592h2), es muy baja, pienso que posiblemente los transistores que estan en la seccion de preamplificador del micro esten atenuando la senal, porque si levanto la base del transistor tr18, la senal de entrada el el pin 2 del ic3 la senal ya es mas amplia y tambien la salida del preamplificador es amplia, pero en la entrada del amplificador de potencia de audio ic4 pin 4 sigue siedo muy pequena, desolde los transistores tr17, tr18, tr19, tr20 y los diodos que estan en esta seccion y los medi con multimetro y midieron bien, asi que pienso que las senales de control de los transistores estan mal.
tambien quiero saber si alguien ha medido con osciloscopio la senales despues del preamplificador o preamplificador de rf en la seccion de recepcion de algun radio que use la misma configuracion del palomar ssb500, porque yo no se como deberian ser , o tambien como probar que el preamplificador de rf esta bien, tambien si alguien ha medido la impedancia entre pines de un filtro de cristal de 7.8mhz, porque yo medi el mio y mide 0 ohms.
El esquematico esta aqui:
</p>
Hi
THanks
Hola
</p>
  • @ Mark Malcomb:
  • @ Naysayer:
    I’m
  • @ kingmudduck:
