Hey gang, trying to fix an older 2950 non-dx, orange display rig for a local friend. His grandson got ripped off in the buy. Paid $200. Hi/Low power settings were turned way down and the thing is way off frequency on all modes.
I've gone through the entire VCO-PLL alignment procedure outlined at cbtricks using a good freq. counter and high accuracy dc voltmeter. All settings at or near dead on the specs. Some points needed adjustment, others were already good.
L27 will change AM freq +/- a couple of kcs as should.
Rig talks great and sees normal+ power output
Prob is unit is about 7.0 kc's low of freq (to round it off) on all modes. Take Ch 19 for example. If you are actually TX/RX on 27.185 - display would have to be on 27.178 to be there.
There is no microprocessor reset button on this unit.
Any suggestions on how to match actual TX/RX freq to Freq display reading? Also frequency deviation is even greater when using CB channel readout mode.
Or stated another way, is there an adjustment to directly change the freq. readout. I haven't see one anywhere.
Thanks for any help
Thanks for any help
