Hello Doc:
I looked that Steppir Vertical Antenna up, I don't think thats a bad deal at 633 dollars, allowing 40 meters thru 6 meters operation. The good thing is that the vertical length is adjustable allowing the operator to have a 1.3 to 1 SWR if one has a good set of ground plane radials.
If one builds a tall vertical with a remote tuner the price tag maybe real close. Had a recent article in QST Magazine showing a remote tuner.
I might get one and install it as a eleveated ground plane on my Barn......?!?!?!?
But with many operators wanting to hear all the HF Ham bands and tune in, the intrest in broad band HF Antennas has increased big time. With the FCC dropping the Morse Code testing requirement for a Ham Lisence. I am getting quit a few e-mails from operators wanting a broad band HF antenna. The cost increase of including 160 and 80 meters is a reality.
Gee Whiz a diploe antenna that offers the low bands such as 160, 80 and 40 meters can sell for well over 200 dollars, with a Balun. And thats not too bad considering a 500 foot roll of 14 gauge wire will cost over 100 dollars, plus the cost of the Balun.
I am sure many will be putting up Inverted "L", Diploles, Verticals, and others to get a start in ham radio. Heah how about a good article / wed site on the inverted V antenna?
I figure there will be a increase in articles in the ham magazines showing all the low cost antennas, and home brew antennas.
I was hearing on 38LSB that a few guys are looking at the shut feed towers for the lower bands. That worlks well, but will need some tuning and adjustment.
Intersting to see what happens.
Jay in the Mojave
W5LZ said:
Lot of "if's" in there! If you've got the room and some tall trees, try an inverted "L" as long as you can make it. You need a very good ground too.
Or the longest dipole possible, feed it with ladder line through a balun or a huge coil of coax.
Would either be a 'good' all band antenna? Eeeeh, sort of, not really, but better than you might think.
Why any of these rather than the 'Steppir'? --> $$$
