Does anyone have an idea on the growing popularity of the fiberglass antennas?
Every truck stop sells them, so that is what is in the case when you go in.
They are cheap compared to center loaded coil antennas.
Tip:
No one single antenna is best for everyone, because almost every mobile antenna install presents different challenges due to height restrictions, mounting location and body style of the car/pickup/truck you are mounting them on.
My own personal rule of thumb:
Stick with antennas that have an overall length of at least 48 inches, this is my own observation after playing radio for 30 years or so.
Forget about the 18" tall center loads, or 2 foot fire sticks....yes i have played with them, and they will tune...but the overall efficiency is just poor.
My fav antennas for mobile:
No longer available 96 inch francis
great antenna if you can find one and get it mounted and live with the height
102' on a solid mount.
Kales Predator 10K ( Not the Comp Coil, Not the 30K, NOT the freedom one antenna these antennas are sales hype) is a decent antenna. I feel the 27" shaft is the best, followed by the 22 " shaft, lightweight, easy to tune. Most helical wound fiberglass whips are about the same.
I have used everything from the Everhardt Tiger 1.5 wave and Quad wrap antennas to wilson superflex, to 96" Radioshack whips with stainless steel braided wire in them.
