New Magnum Radio Info
C
CBTricks
Guest
I put Information on the following new radios on the CBTricks.com site, these are not on the market as of yet The Mini Magnum should be out the late part of September and the S3 and S9 after that.
Magnum S3
Magnum S9
Mini Magnum
As I get time to play with them I will put up more info.
Please Note that this information was put together using a PRE Production Radio.
There will be some differences in the final product.
So check back for updates!!!!
Bennie
www.cbtricks.com/
</p>
Hats off to Magnum for employing the handicaped.....They MUST be using blind people to design the front panels. <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin">
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=hook948@worldwidecbradioclub>Hook948</A> at: 9/1/03 2:37 am
Ray at RF Limited? Sure you don't mean Ray at Galaxy?
The owner of RF Limited had these chassies' mf'd independently, although they look similar to the ranger/galaxy chassies, they are not made by them. Same as he did with the previous Magnum lines, 257, Delta, Alpha, Maverick, and Omega.
You can also ask Bob from Bob's CB & Wireless
whom has done extensive work for RF Limited on these new radios.
Wm. Warlock "71 and the long black limousine in Va"
Rollingradios@aol.com
Nat. Rep for XForce/Magna Force Customer Service and Support
</p>
I have questions??
I certainly hope the folks engineering the new Magnums have put some serious effort into the rx on these radios. The current and older models of Magnums rx is way, way too noisy, and not near sensitive enough. The small close together knobs on the face plate are way too close together and very cheap. If they have made some real improvements, they might have a customer here... Did ya' hear me RR???<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek">
Hossless<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/alien.gif ALT="0]">
</p>
I have the same gripes Hoss, but I'm still going to buy one of each and try them!
</p>
All RF Limited had to do was fix the recieve in the Delta Force and they would have had the "Best and Baddest" AM/SSB radio on the planet!
Too bad these new radios don't have the memory channel setup that the Delta's have! That was the handiest feature I've seen in a mobile radio! 2 buttons changed channel, operating mode, and band!
Oh well!
JD<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat">
<span style="color:yellow;font-family:verdana;font-size:medium;">CDX 951</span>
<span style="color:yellow;font-family:verdana;font-size:medium;">JD'S NEW DX SPOT
</span>
</p>
    Greg T has left the room.
