Here it is! The perfect example!
You are thirsty (need an antenna). There are a number of choices in the 'pop' machine (bunch of different antennas). There's a problem though, each choice, Pepsi, Coke, Sprite, etc, are a different price (different antennas have a different input impedance). The 'pop' machine can't make change, you have to have the exact change (the antenna isn't an auto-tune one). So, because you don't have a big selection of coins, you can't deposit the exact price for any of the selections. Which means that you will either get a real bargain, or will over-pay for whichever selection that you pick. That 'bargain' doesn't sound bad, but if YOU are the owner of the 'pop' machine, you are gonna come up short when you count the deposits, right? The deposits being what goes to pay bills, and also just happens to be the signal you radiate from the antenna... ... See where I'm going? The only way that everybody comes out 'even' is if the price of your choice (antenna's input impedance) is a set, fixed, price (the coins being the 18 feet of coax.). One size fits all, or you'd better have a lot of change.
(Okay, maybe it isn't the 'perfect' example, but it's close. You've got a choice; lots of change, different 'types' of coax of different lengths. Or just make the price the same for everything, tuned input. Then it doesn't matter what change you happen to have, or baggy pockets.)
'scuse me while I go take my medication...
